GregValiant 1,330
There won't be anything in the gcode that references "filament errors". If your printer is randomly pausing something is telling it to.
The typical pause commands used by post processor plug-ins (like PauseAtHeight and FilamentChange) are M0, M600, M25. If You aren't using either of those Plugins then it's most likely the printer is signalling itself to pause.
Start a print and manually trip the filament sensor to try to reproduce the behavior.
cmxdiver 0
I have the same problem where the print pauses or gives repeated filament errors. This is when I use basic settings. When I use other quality settings this does not happen. I have checked the fillament sensor and its not the problem. Any advice? I am willing to inspect the gcode but not sure what to look for.
