Rippling / Ghosting on cilinders on (brand new) UM S5.
waldo
Posted (edited) · Rippling / Ghosting on cilinders on (brand new) UM S5.
You will not be able to compare the "fast" CPE to "fast" PLA, CPE have some overruling settings that make the "fast" CPE lock a bit like "normal" PLA.
Fast PLA:
"Outer wall speed" 50 mm/s
"Inner wall speed" 55 mm/s
"Outer wall Acceleration" 2000 mm/s
"Inner Wall Acceleration" 2000 mm/s
Normal PLA:
"Outer wall speed" 23 mm/s
"Inner wall speed" 45 mm/s
"Outer wall Acceleration" 500 mm/s
"Inner Wall Acceleration" 1000 mm/s
Fast CPE:
"Outer wall speed"  35 mm/s
Edited by NBull
    Posted · Rippling / Ghosting on cilinders on (brand new) UM S5.
    @waldo, the surface finish is significantly better with a .35 line width.
    As mentioned earlier, set all speeds and jerks to the same value and you will see a major improvement in quality and also in dimensional accuracy.
    Will try it for sure
    Do you think this would apply to me with CPE @ 60mm/sec? Set them all to 60.
    5 hours ago, NBull said:
    Hi, I agree that the "fast" profile is shit, and I can't really see any use for it. But to be fair there are some significant changes between normal and fast beside the layer height.
    "Outer wall speed" goes from 23 mm/s to 50 mm/s
    "Inner wall speed" goes from 45 mm/s to 55 mm/s
    "Outer wall Acceleration" goes from 500 mm/s to 2000 mm/s
    "Inner Wall Acceleration" goes from 1000 mm/s to 2000 mm/s
    Interesting. I'm using Cura 4.3.0 on an UM3E. As I mentioned, the speeds are different, but my accelerations for both fine and fast profiles are the lower values.
    I don't have much experience in CPE so (disclaimer 🙂)  if it's much different from other materials.
    But in general yes, if you opt quality over speed, setting all to the same low speed will help the quality.
    I would say you should go for 40 mm/s or even 30 mm/s on all speeds.
    Apparently the difference lies in the printer.
    It's a long time since I used an UM3 so wasn't aware that there was a difference.
    My mistake.
    S5
    1932953148_ScreenShot2019-10-18at14_24_01.thumb.png.b4f505021e9243813be9b9ebcfbac0c0.png
    UM3e
    550802485_ScreenShot2019-10-18at14_23_31.thumb.png.5533f0974072877557c6f706562ea6ec.png
    Edited by NBull
