The answer depends what printer you have. UM3/S3/S5. If you have a UM3 then I recommend you disable automatic leveling and do a careful manual level.
However I suspect this is an S5. Something is going wrong with the autoleveling I think. The second head is too close or too high off the glass (you can verify by pushing up or down on the glass while it prints with the second head and filament should stick nicely).
Autolevel failures are usually caused by spring issues. You basically need the spring in the cores to be stronger than the spring in the bed. This is a simplification but often one needs to make the core springs stronger or the bed springs weaker.
You can weaken the bed springs by moving the bed up a bit so the 3 springs are compressed less. Try 10 rotations of each of the 3 levelling knobs, then redo manual level. You can test the cores by putting the nozzle on a postage scale and pushing down until you first start to see a tiny bit of movement. This should happen at 1.0 kg (or higher). Less than 1kg force needed means the core may have vertical calibration issues.
Which model printer do you have?
1
waveletlet 0
Silly me, I never measured my test objects. When I said prints with the head could successfully finish and look normal, I was actually wrong! Theyr'e about 2 mm short.
This all started happening after I updated my firmware from something over a year old to v5.2.11.20190503. Unfortunately I didn't take note of what the previous firmware version was. After the firmware update I did an XY calibration and the 2nd extruder came out all ghostly as above but I thought it was a filament (wet, old...) issue and ignored it.
