Use one filament only if possible. if Pva is used be sure that it doesn't string or ooze. since this can be caught between the layers and make holes.
Go with a decent layer height 1.5
Print at relativly hot tempetures
Extrusion Width can also help since it forces the layers to bond more eg. 0.48 on a 0.4 nozle 120% increase
Edited by NBull
DivingDuck 69
Adding some extra walls and printing with slightly higher print temps can improve tightness. You need to play with these parameters a bit to find out a good compromise between surface and function.
