Posted (edited) · Create a new Postprocessing Script
Hello,
I'm trying to create my own postprocessing script. The goal of the script is to add at the beginning of the GCode file different comments to keep the print profile.  For the print parameter I don't have anny problem to get the values , but I don"t know how to get the Name of the profile and the initial material name.  I'have made a test with a command line like :
GetValStr = Application.getInstance().getGlobalContainerStack().material.getMetaData().get("material", "")
but this line return an empty value.  hereafter the actual sample code
import re #To perform the search and replace.
from ..Script import Script
from UM.Application import Application #To get the current printer's settings.
##  Performs a search-and-replace on all g-code.
#   Due to technical limitations, the search can't cross the border between layers.
class Documentation(Script):
    def getSettingDataString(self):
        return """{
            "name": "Documentation parametres",
            "key": "Documentation",
            "metadata": {},
            "version": 2,
            "settings":
                "search":
                    "label": "Search",
                    "description": "All occurrences of this text will get replaced by the parameter list.",
                    "type": "str",
                    "default_value": ";FLAVOR:Marlin"
    def execute(self, data):
        search_string = self.getSettingValueByKey("search")
        search_regex = re.compile(search_string)
        replace_string = search_string
        replace_string = replace_string + "\n;==============================================\n;  Documentation\n;=============================================="
        #   machine_nozzle_size
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("machine_nozzle_size", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("machine_nozzle_size", "label")
        replace_string = replace_string + "\n; " + GetLabel + "              : {Val} mm".format(Val = GetVal)
        #   material_guid
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("material_guid", "label")
        replace_string = replace_string + "\n; " + GetLabel + "     : " + GetValStr
        #   layer_height
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("layer_height", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("layer_height", "label")
        #   line_width
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("line_width", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("line_width", "label")
        #   material_print_temperature
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("material_print_temperature", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("material_print_temperature", "label")
        replace_string = replace_string + "\n; " + GetLabel + "         : {Val}°C".format(Val = GetVal)
        #   speed_print
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("speed_print", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("speed_print", "label")
        replace_string = replace_string + "\n; " + GetLabel + "                  : {Val} mm/s".format(Val = GetVal)
        #   speed_infill
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("speed_infill", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("speed_infill", "label")
        #   material_flow
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("material_flow", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("material_flow", "label")
        replace_string = replace_string + "\n; " + GetLabel + "                         : {Val} %".format(Val = GetVal)
        #   retraction_enable
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("retraction_enable", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("retraction_enable", "label")
        replace_string = replace_string + "\n; " + GetLabel + "            : [{Val}]".format(Val = GetVal)
        #   retraction_speed
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("retraction_speed", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("retraction_speed", "label")
        replace_string = replace_string + "\n; " + GetLabel + "             : {Val}".format(Val = GetVal)
        #   support_enable
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("support_enable", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("support_enable", "label")
        #   support_type
        GetValStr = Application.getInstance().getGlobalContainerStack().getProperty("support_type", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("support_type", "label")
        #   infill_sparse_density
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("infill_sparse_density", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("infill_sparse_density", "label")
        #   infill_pattern
        GetValStr = Application.getInstance().getGlobalContainerStack().getProperty("infill_pattern", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("infill_pattern", "label")
        #   material_diameter
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("material_diameter", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("material_diameter", "label")
        #   ironing_enabled
        GetVal = Application.getInstance().getGlobalContainerStack().getProperty("ironing_enabled", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("ironing_enabled", "label")
        #   adhesion_type
        GetValStr = Application.getInstance().getGlobalContainerStack().getProperty("adhesion_type", "value")
        GetLabel = Application.getInstance().getGlobalContainerStack().getProperty("adhesion_type", "label")
        #   Fin de commentaire
        replace_string = replace_string + "\n;=============================================="
        for layer_number, layer in enumerate(data):
            data[layer_number] = re.sub(search_regex, replace_string, layer) #Replace all.
        return data
Edited by Cuq
change title
    Posted · Create a new Postprocessing Script
    A printer has one global stack that has common settings, but it typically has no materials. A printer also has one or more Extruder Stacks. You need to get the material from the extruder stack. This might work (but I have not tested it):
    GetValStr = Application.getInstance().getGlobalContainerStack().extruders[0].material.getMetaData().get("material", "")
    There are other settings that you should be getting from the extruder stack too, like material_diameter, material_flow, retraction+*, material_print_temperature, machine_nozzle_size, infill_*, speed_*
    There's a lot of code duplication in your script. You don't need to get the global stack over and over again; store it in a variable.
    • Thanks 1
    1 hour ago, gr5 said:
    This is beyond my knowledge but maybe @burtoogle or @ctbeke or @ahoeben can help or at least know who can.
    For the the majority of these parameters ( material_print_temperature, machine_nozzle_size , material_diameter etc ) . GetProperty function retrun the right values.
    But I don't find any parameter for the profil name  and the material base.
    Doesn't seems to be a valide solution
    Ok step by step I'm closer to my goal   to get the Material name I'm using this code :
            # add extruder specific data to slice info
            extruders = list(Application.getInstance().getGlobalContainerStack().extruders.values())
            GetValStr = extruders[0].material.getMetaData().get("material", "")
    Does anyone of you knows how to get the Profil name ?
    Edited by Cuq
    Sorry, GlobalStack.extruders returns a dict, not a list. You could try
    ...getGlobalContainerStack().extruders["0"].material.getMetaData().get("material", "")
    For the profile, try this direction:
    ...getGlobalContainerStack().extruders["0"].qualityChanges.getMetaData().get("name", "")
    AND
    ...getGlobalContainerStack().extruders["0"].quality.getMetaData().get("name", "")
    Use the quality one if the qualityChanges one returns empty.
    Edited by ahoeben
    Thank you @ahoeben !!!!   That's OK :
    • Profile name
    • Material name
    • Quality
            #   Profile
            GetValStr = extruders[0].qualityChanges.getMetaData().get("name", "")
            GetLabel = "Profile"
            #   Material
            GetLabel = "Material"
            #   Quality
            GetValStr = extruders[0].quality.getMetaData().get("name", "")
            GetLabel = "Quality"
