Hi Aoeben,
I was going through one of your suggestions
“If you enable the developer mode, you can SSH into the Linux board, and though the code that lives there is not open source it is mostly Python and can be edited.“
Can you please tell me how to change the gcode in Ultimaker S5 in real time. I am already in developer mode.
Thank you so much.
I really appreciate your help.
ahoeben 1,968
In theory, sure it is possible. In the S5, there's a Linux board that hosts Cura Connect and Ultimately sends gcode to a Marlin-based printer controller board. If you enable the developer mode, you can SSH into the Linux board, and though the code that lives there is not open source it is mostly Python and can be edited.
In practice? At best you'll end up with a working edited firmware, and you will have to make your changes/additions again and again when new firmware is released.
