Thanks, good idead, I'm gonna try it after checking the carriage didn't have some unexpected problem before printing from printer.
Ok, mystery resolved : when cura crashed at the first print, I didn't save the settings, so you were right the 2 gcode weren't the same. Thank you !
Mystery solved 🙂
Thanks for the feedback!
Smithy 1,108
I don't think so, I guess you the GCode was not exactly the same between the two prints.
Try it if you save the GCode first to a file, then print from Cura and then use the saved file to print from SDCard.
The procedure is basically the same, when printing via card, the GCode is processed line by line and when printing via Cura, the GCode lines will be sent line by line via USB. So there is no more magic.
