I had similar issues when I have used one of the default profiles.
After equalizing all the speeds except the travel speeds to the same value, the gaps never occurred again.
But it is generally better to set all the speeds to the same value, which gives also better dimensional accuracy.
TheodorK 11
I also used to have this issue, and in my case it was fixed by decreasing the print speed. Because the gaps only show on long straight lines, and nog in the corners or in short lines, it is probably because there is nog enough plastic extruded to compensate for the movement speed.
