DivingDuck 85
You are wellcome. Maybe this makes it a bit more clear. I can't activate the second one with the red arrow. Is it rotation y? I'll try to figure out what this axis command is called in the xml config file of 3xd and how to put this in your config file.
It would be great if you will be some when able to read out the original xml config file (a whish for future improvements 🙂 )
burtoogle 508
Thanks for the feedback. I'm not sure what you mean by flipping the bed on the y axis. If you mean change the direction of movement, that can easily be accomplished by editing the config file and changing the sign of the appropriate scale value. You don't even need to restart cura, just goto the RawMouse menu and restart to read the new config file.
