How to print 1mm upin zaxis
shrikant
Posted · How to print 1mm upin zaxis
HI,
I need a support, Well i am printing a device model which has a one pipe extension so when i importing my model in Cura 4.2.1 its default value fix at printing plate and the round part of my object touches the plate, in that case my print is getting lost its specifications, so please suggest how i can start my print 1 or 2 mm upward from the bed with supports so my print dimensions getting same.
Please find the attached images for the reference.
Thanks
    This is easy.  First go to menu "preferences" "configure cura...".  Among the many checkboxes on the general page, uncheck "Automatically drop models to the build plate".
    Now you can move your model up with the move tool that you show in your first photo.  You can also move the model *down* below the bed and it will chop off the bottom of your model which I find very helpful for parts that are not quite flat on the bottom.
        • 24 replies
