fbrc8-erin 265
If your fans buzz briefly, then your main electronics board is getting power. That means the issue is most likely at the wifi board or Olimex. Since you've already tried booting up without the wifi board, my best guess would be that the Olimex board is failing. You could try re-imaging it, but given that it's not stuck on the Ultimaker logo screen at this point, I'm more inclined to think it's a hardware issue rather than a firmware one.
So you think he needs a new olimex board?
@Sergio1288 - how old is your printer? Might it still be under warranty?
Thanks for the help. I've had the printer little over a year, so warranty is problem not an option
Well it's definitely worth it to buy a replacement olimex from fbrc8 if you decide the problem is the olimex board.
gr5 1,877
Often it is the power brick. These things are way too complicated and have too many parts that can break (reminiscing about the good old days when power supplies were simple).
I actually had a power brick that if I unplugged it from power for a few hours it would come back to life. A *different* power brick (both for Ultimaker printers) died for 24 hours - still wouldn't work. Threw it in a box for a year. Now it works fine!!
