Cura changed build plate size on S5 - parts no longer fit
Rolaids
Posted · Cura changed build plate size on S5 - parts no longer fit
I laid these parts out in Cura 3.6 about a year ago. Printing on S5 every week and worked great. I then upgrade the S5 with the Air Manager and need to reslice with Cura 4.4.1 to add build volume temp settings. Now it thinks the parts won't fit. I really need to over ride this or get it fixed!!
See attached screen shots.
Thanks for the help,
Roland
    Might be a long shot but I have seen Cura sometimes think its a dual extrusion print, even if it isnt, and if Prime tower is enabled it will shrink the print area.
    This support page mentions all settings that have an influence on those "forbidden areas". It's still valid for the S5.
    https://ultimaker.com/en/resources/44677-maximum-build-volume-ultimaker-2-plus-ultimaker-3
    Good luck!
    3 hours ago, Framar said:
    Is the machine settings are the same in the preferences ?
    This is in 3.6
    The machine settings are identical between both versions of Cura.
    Good luck!
    Thanks for the suggestion, but nothing changed when adjusting these settings.
