Yes just checked with X-rays view there is hole inside the object. and for the third model you are right . walls are too thin . How can I fix these issues ? can Cura fix these ?
I have another question : Does anyone know which format of sd card should be used for CR10s pro ? my sd card sometime shows files sometimes doesn't. I want to reformat sc card . so does not know which format . I use MacBook Pro (Catalina )
ahoeben 1,152
The most likely cause of the first two is that the model is not manifold. Inspect it in X-Ray view, and it will probably show you parts in red. The models need to be fixed.
For the third example, I think the part is just too thin there.
