Hi robobartz,
18 hours ago, robobartz said:A major design flaw of the 5S is the inabiltiy to adjust belt tension on the main belts (you can adjust belt tension from the drive motor to axis, but that is only 1/2 the tension required. Ultimaker should take note of the cheap consumer printers like Creality where you can adjust belt tension easily. We like the Ultimaker overall but just pointing out something to improve in the future.
I disagree. The Ultimaker printers are -at least since the UM2- equipped with an automatic belt tensioner for the long belts, which is integrated in the sliding blocks. If the belt gets loose at the opposite side (lower at front/back belt, higher at side belts), there is an easy way to tighten them again, as shown in the following video, provided by @fbrc8-erin:
Regards
1
1
robobartz 3
We had an incident not long after we bought our 5S that the print head crashed and pushed the glass free of the clamps and scratched the aluminum platter below. It happened on the weekend during a long print. When we left the factory on Friday, it was operating completely normal. We think it was due to a power spike/fluctation surge as our facility is in a rural area. The hot end actually came in contact with the aluminum under the glass and put a scratch into it. In order to do this it pushed the 3D print to the side and overcame the resistance of the bed clamps. On Monday we found the glass pushed to the side. Call it impossible, but it happened. Since that time our right/left belt is loose. It must have tried to self-correctedsomehow because it proceeded to print the rest of the 3D print as a birds nest of material.
Edited by robobartzLink to post
