Well, maybe, but It cannot be much simpler.
It happens as soon as the wall thickness is close to the nozzle width (in this case 0.4) somewhere between one and two nozzle width (so 0.4-0.8mm)
Basically, as the tube is a mesh, both inner and outter circles have 128 vertices.
The distance between them is roughtly 0.45mm to ensure that 0.4mm is always there.
It's a simple extrusion. Please find an exemple attached.
gr5 1,858
Wow. I suspect the model in this case.
