Hi saroneh,
This screw terminal consist of two blocks and each have 3 terminals.
Here is the manufacturer (Phoenix) P/N: 1888690
Also Digi-Key P/N: 277-6062-ND
Here is a direct link:
Edit: Digikey is located all around world, there might be one close to your place.
Good luck.
Thanks
Torgeir
Edited by TorgeirAdditional info.
IRobertI 513
It's not about what temperature you set the bed at. What has happened here is that the wires were no longer held firmly in place, this leads to a poor connection with a high resistance. When the printer then powers up the bed that leads to heat being generated in the point where the wires connect to the board and it causes them to melt.
You should be able to get a new board from any local Ultimaker reseller.
saroneh 0
Hi Robert
Thank you for the reply!
Would it really be necessary to replace the entire board?
I was hoping for a fix that didn't cost above $100.
Why not just replacing the connectors on the board or using the temp2 outlets? Of course, the later will require recoding the software.
