cura 4.6.1 e retraction
Posted (edited) · cura 4.6.1 e retraction
Hello everyone, I have a fairly serious problem, in the machine setting, on the starting script of the print eg:
G21; metric values
G90; absolute positioning
M82; set extruder to absolute mode
G28
G1 X0 Y0
G92 E0; zero the extruded length
G1 F200 E20; extrude 3mm of feed stock
G1 E-2
G92 E0; zero the extruded length again
G4 P6000
The retraction is not -2mm but becomes -20mm why?
Edited by mario69
    Posted · cura 4.6.1 e retraction
    17 minutes ago, DarRAven said:
    what do you mean by "The retraction is not -2mm but becomes -20mm"?
    I mean that if I set a retraction of the filament of -2mm then the SW does not do it but it portrays me a lot more than 2mm I also arrive at -20mm
    Why should deleting G92 E0 solve the problem?
    G1 F200 E20
    G1 E-2
    because the e-axis moves (slowly) from E=20 to E=-2 (22mm backwards)
    Those are absolute coordinates like set with M82 a few lines above.
    Here is a quite comprehensive gcode overview: https://reprap.org/wiki/G-code
    2 hours ago, tinkergnome said:
    perché l'asse e si sposta (lentamente) da E = 20 a E = -2 (22mm all'indietro)
    Quelle sono coordinate assolute come quelle impostate con M82 poche righe sopra.
    Ecco una panoramica del gcode abbastanza completa: https://reprap.org/wiki/G-code
    everything works, it was my mistake, sorry for the
      time that I made you waste
    It's okay.  You just helped the next person who googles about this same problem.
    1 hour ago, gr5 said:
    Va bene. Hai appena aiutato la persona successiva che cerca su Google lo stesso problema.
