Nozzle still appears to be blocked and atomic pull method isn't working to clear it
Posted
· Nozzle still appears to be blocked and atomic pull method isn't working to clear it
Years ago I described my more gentle atomic pull method, but it also had a couple of other tips that I use. The main difference with the standard method, is that mine is much more gentle, less hard on the machine, but with equally good results.
Regarding the amount of black residu on this pulled-out piece, it looks like the nozzle needs additional cleaning indeed.
geert_2 560
See here: https://www.uantwerpen.be/nl/personeel/geert-keteleer/manuals/
After doing an atomic pull, you should be able to see through the nozzle from above.
