Hello,
To answer: “That top image looks under-extruded and the layers don't look bonded together. Is that what you mean by "not solid"(?) “ Yes that is what I mean by not solid. It isn’t properly bonded and the infill becomes very “stringy”. I don’t think it’s the G-code because I had printed the same object the day before and it printed fine (it was nice and solid and properly boned) but when I went to print the exact same part today it didn’t work.
Edited by classified
GregValiant 1,307
It would be odd for the printer to be making things up by itself. Really odd for multiple printers to making up the same stuff.
That top image looks under-extruded and the layers don't look bonded together. Is that what you mean by "not solid"(?) or is it more like vase mode and missing infill?
You have tried checking with a Gcode file you know is OK (like one of the bench models)?
