Hi Nico,
Thank you for your post.
Obviously, the mod also caught our attention and I can see some pro's and cons to it.
We choose not to do it because once assembled, it is very reliable but it is a rather precise and difficult assembly and would make the assembly and design more complicated. Getting it accurate for 1 machine is one thing, but for 1000+ machines is a different story. The small belts might need some adjusting in a future stage, but it is much easier, faster to build and easy to adjust if necessary.
@GR5, why would you move your belts to the outside?
gr5 2,210
Having the motors stick out the sides of the UM makes for more things to bump into and your motors mean you have to position the UM farther away from any walls and it's uglier. And the short belts work fine for me.
If you transport your UM often you will be glad the motors are out of the way.
However I've been thinking of moving mine to the outside (but still using the belts). It requires no extra hardware, no holes drilled, just swap the X,Y direction bits in software (or in hardware jumpers).
