Hello,
I hope you don't mind, I've updated the title of your post to better describe your question.
Have you also checked if esumi offers motors with a changeable rod? I hope you realise the modification you are considering is quite impactful on the motion system on an Ultimaker and it is not as easy as just replacing a belt by a rod.
If I remember correctly, but I am not a mechanical engineer, a rod can be more precise but at the same time it requires a more precise assembly with less margins than what a belt is comfortable with. Adding multiple rods introduces multiple levels of complexity. A belt might be slightly less accurate but it is much more forgiving at the same time. So I am not sure if the investment would justify the marginal improvement. Did you feel like the Ultimaker 2 was not accurate enough?
3d_rockstar 0
No ideas?
