Same problem here... UM2+ is about 6 years old.
@Riboflavin did you solve your issue? The chip would be easy to replace, but if it's just a symptom and not the cause, we should find the cause first...
Diode D16 was also broken, as @Torgeir suggested. Will replace U6 and D16, let's hope this will work.
I found a few "classic bugs" on the PCB... Could they sufficiently conduct to kill the regulator? I assume a component failure is more likely...
Hi, I had same issue. Got it repaired and the same component died again.
I bought £60 board through aliexpress , fitted, updated firmware and works fine.
6 hours ago, Alexjwb123 said:Hi, I had same issue. Got it repaired and the same component died again.
@Alexjwb123 did you also replace the diode D16, or only U6?
Ah just u6.
I didn't realise diode needed replacing too,
I can confirm that in our case replacing U6 and D16 helped! The UM2+ is again printing happily, for the cost of about 2$ of spare parts 🙂 Already has almost 5000 printing hours.
In order to replace the parts, you'll probably need a hot-air rework station, solder paste, flux and maybe a desoldering station (vacuum pump) for cleaning the pads after desoldering. I ended up both desoldering and desoldering the IC with the hot-air rework station.
Edited by dbrgnHi @dbrgn,
Way to go.. Thanks for the feedback!
The Power supply is in general the fault of about 80 percent of all failures in the electronics, -in general.
So about 20 percent of the failures is of other causes...
This is all said by experience over a long time. 🙂
Thanks
Good luck.
Torgeir.
Here's a blogpost with a summary of the repair: https://www.coredump.ch/2020/08/25/ultimaker-2-repair/
Edited by dbrgn
Torgeir 247
Hi Chris,
I'll think this happen (reported) in here once as far as I'll remember.
As this regulator make 5V DC, you may try to use an ohm meter to see if there is any direct short.
This mean it's something wrong in the main PCB, but could also be the converter's sub components.
Also the diode D16 is something that's fail in such an "inductive" converters.
There is an instrument named trackers, handy for identifying components with shorts.
There is repair centers that handle such repair..
Good luck
Torgeir
