If you plug your printer directly into Cura, you can give it manual codes I believe, I don't know G-code that well so I never tried but it shows it under the "monitor" tab.
Perhaps there's a way to do it like that.
But I doubt it since it's all coordinates, you'd have to figure out where it was and remove each line of code that tells it to there.
Yeah, I wouldn't mess with it, either scrap it all or let it finish, when it happens to me, I just let it roll unless it's catastrophic.
SandervG 1,499
Hi @samuidayone, thank you for your message and welcome to the community.
If I understand it correctly you wish to basically halt a print, and resume with a different gcode (which contains of the same print job except 1 model). I don't believe that is possible right now. Perhaps someone knows a possible workaround?
samuidayone 0
Thanks for the response!
It would be pretty neat if there'd be a workaround. It's not a huge problem but saving time and material is quite an idea.
