On 7/22/2020 at 6:11 PM, robinmdh said:or maybe print with the new engineering profiles?
This would be a good suggestion, if the engineering profiles were available for the UM3.
On 7/22/2020 at 6:11 PM, robinmdh said:but we haven't planned to do any more UM3 software updates at the moment
That's very sad to hear, despite the principle "never change a running system".
Regards
Edited by Enigma_M4syntax
robinmdh 70
For the UM3 you mean?
It does take double the roll amount to roll over to the start vs to roll to the next item.
we did considered this, decided against it because of some fairly long menus and if I remember correctly it should be easy to change but we haven't planned to do any more UM3 software updates at the moment.
I suggest printing a custom knob for the printer control, that makes it a lot more controllable IMHO.
https://www.thingiverse.com/search?q=ultimaker+knob&type=things&sort=relevant I used the 2nd one in the search result myself, did have to scale it down a tiny bit, or maybe print with the new engineering profiles?
