This happens a lot on both UM1 and UM2 when printing through USB. Did you get the ulticontroller I hope? If not the solutions are to vary the USB in some way. For example try a different computer (laptops seem to be more stable for some people plus they have built in battery if you lose power) or buy a $10 USB hub which amplifies the signal or route the USB cable differently or try a better USB cable.
But if you can print through the ulticontroller, this kind of thing doesn't happen.
I have successfully continued "failed" prints but it's a bit of work - you basically remove the gcode up to the spot where it left off. Plus leave in the homing code and you have to do a trick to get the extruder not to suddenly extrude a meter of filament because it thinks it's one meter into the gcode. But it's not too hard to do. The trickier part is figuring out exactly where it ended up (stopped).
IRobertI 502
What did the gcode look like? Can you try repeating the same procedure in cura and then looking in layer view to see what cura produced? Alternatively, and probably preferably, try downloading Repetier Host http://www.repetier.com/download/ and take a look at the original Gcode. If you don't feel comfortable doing that you can upload the gcode somewhere and link to it so that one of us can take a look.
This is just to rule out that something is wrong with the produced gcode.
Also, I hope you're not planning on actually using those stirrers. For one, if you're using PLA, they will melt. And the plastic we're using isn't food safe.
