Carla_Birch 116
With PETG you want to run the printer with as little part cooling as you can, for parts with no details you can run with 0% cooling fans to get strong layers, if a part as more fine details run cooling fans at 50%.
If its printing in a area open to cold drafts, its best to try and limit the draft (for any 3d printing really) to stop it cooling to fast. Also you might need to up the printing temps to get better layer adhesion, or print a little slower.
1
tinkergnome 927
Not necessarily, but it helps of course.
Don't use the part cooling fan for those big objects and try a different filament first.
If this is "silver", use a different color - i don't know why, but these glittering additives make it much more worse.
Framar 38
I've noticed that when I printed at slower speed I got better layer adhesion.
igniparra 0
Thanks! I will try that, also to prevent blobs and boogers...
The other one I bought was Cobalt... A lot worse than the silver one...
Yes, we don't get quality filament in Argentina, but I wanna get the best results with what I get, and I think I can do better by tuning the settings.
Thanks!
