Ultimaker 2 Pro won't print solid
jhnk
Posted · Ultimaker 2 Pro won't print solid
Do you mean Ultimaker 2 Plus?
What material are you trying to print with?
What settings are you using?
What nozzle are you using?
Is it a new machine, an old one, something inbetween?
Has the printer worked fine before?
Does it happen with all prints or just this particular one?
What steps have you tried so far to troubleshoot?
In short, we need a lot more info to be able to help.
    Thank you for your replies.
    It does the same with 100% or less infill. With less than the grid is also these wisps, see photo.
    It sais "Ultimaker 2 Go", not "pro", sorry.
    The material is plastic? I'm not known with the component of the printers, I just know a little bit how to use them. It is not my printer, I just use it. I don't know what nozzle, sorry.
    I have done the same thing with a other printer in the past, ant that worked fine, now I use this one and it doesn't work.
    I first make the model in SketchUp, than open that in CURA and make it a gcode. See attachments.
    I do not know if this printer has worked ok in the past. This does however now happen to all prints I try with this printer.
    What I have tried is changing settings in CURA, like Wall Thickness, Top and Bottom Thickness, Infill ofcourse, Speed.
    I have not changed anything in "Dual Extrusion", those settings seem to complicated for me.
    Does someone recognize this and knows what I have to change?
    UM2GO_schakelaar alles v2.gcode schakelaar alles v2.stl
    It's crucial that the printer is configured for the exact material type that you feed into it.
    The UM2go is meant to be an "PLA only" printer (AFAIK) - but it has to have the correct diameter (2.85mm) as well.
    Your pictures look like you either used the wrong material type (anything different from PLA) or the wrong material diameter.
    If unsure - show a picture of the material spool. Doesn't it have any label on it?
    In short: the first thing to check is if the material settings on the printer are matching the used material.
    Once this is confirmed - we can work out about maintenance, consumables and repair....
    They removed the material, so I don't have any information. Apparently I have to bring my own material from now on.
    Thank you for the information! "PLA only" printer (AFAIK) - diameter (2.85mm)
    Beside from the material, is there something in the "Dual Extrusion" settings that I have to ensure?
    The UM2 Go is a single extrusion printer, only one nozzle, so dual extrusion settings are irrelevant in this case. Looking at the latest picture, the plastic that is loaded looks quite thin but I'm not 100% sure. But yeah, that's the first thing to make sure, the diameter should be 2.85mm (sometimes sloppily called "3mm"). Not 1.75mm which is the other standard and that will not work.
    Underextrusion is a complicated problem with many possible causes:
    https://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#underextrusion
