This is, apparently, a known problem: a small number of recent shipments got the wrong power supply. Open a support ticket at support.ultimaker.com and they should have you sorted out ASAP.
Thanks for the prompt replies guys. Much appreciated.
Daid posted this picture earlier, the right one is the one you should have. http://daid.eu/~daid/IMG_20131217_170635.small.jpg
The problem is probably not the power supply. If it was it would have shut down. Instead it is likely in the wiring or most likely in the solder joints on the bed. Read this thread/topic here which includes photos:
http://umforum.ultimaker.com/index.php?/topic/3745-had-a-problem-with-my-um2-heated-bed
gr5 2,225
Ultimaker accidentally shipped the wrong power supplies for some UM2 machines and they just discovered it today. Please send a photo of your power "brick" that shows the amperage to Ultimaker support and they will ship you a new one immediately.
In the mean time, I recommend putting some blue tape over the glass (should have been included) and print on cold glass. You can even print directly on cold glass if you use the glue stick, use hot PLA. More details on printing on glass here:
http://umforum.ultimaker.com/index.php?/topic/3404-printing-on-glass/
edit: for example print first layer at 240C and use glue stick and you should be fine. You can lower the temp when it starts the second layer.
