thanks for the input, I did not notice the min speed.
So my min speed is set to 10mm/sec, ganrty=0. I am not sure it's slowing to 10mm/sec but I will watch is closely to see if this is the limit I am reaching. (normal print speed 70mm/sec)
Multiple objects might be the way I need to go.
cor-kiekens 0
There is also a setting "min speed". Regardless of how slow your printer wants to move to stay above the desired min layer time, it won't move slower than this min speed. But lowering this"min speed" even more than standard setting I'd not really recommended. This will transfer so much heat from the slow moving head into your print that you will get blobs etc. try printing 2 or more objects at once... Be sure to set your gantry height at 0. (found in printer settings)
