My little details keep falling into the infill abyss!
Posted
· My little details keep falling into the infill abyss!
In such case I would use a thin block as a support blocker and assign it a 100% infill. Or I would split the 3D model at the location Where the 100% infill is needed and stack them on each other so you get top layer of the fisrt block and then bottom layer of the second one.
Posted
Or leave a gap of 0.01mm between the plate, and the studs, in the same CAD-model. So the plate would print as one block including top layers. And then there would be a 0.01mm vertical gap, after which the studs are printed. Such a tiny gap will obviously be filled, and the studs will fuse to the baseplate as if there was no gap.
I don't think this is the optimal way of doing it; too much CAD-work. Beter would be to find the exact right slicer-setting to handle this (if present). But it might be a way around if nothing else works...
Posted
Thanks @geert_2. That is like my option 2, which is what I am using now. All I did is put a 0.2mm thick disk-shaped void right at the base of each stud. The print looks very clean and I get neat ceiling layers at the top of the whole block, right before the studs print. But then there are redundant floor layers at the base of the studs.
If I could just specify a "100% infill at layer #", I could specify the ceiling layers of the big block, and the studs could continue printing as if they were the only things on the bed (as in no additional floor layers for them).
Or is there a way to turn of the generation of certain ceilings and floors at s specified layer?
...Just got a brain wave while writing this! I should intentionally make my studs hollow. That will get rid of redundant floor layers of the studs. And a 7mmø cylinder doesn't need any infill anyway. I will still have additional ceiling layers right under the studs that would would be a bit of a waste of materials. But the trade-off is that the speed of the ceiling of the block will be maxed.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Framar 38
geert_2 557
spauliszyn 0
