Wifi is great when it works reliable, but this is often not the case and there are hundreds of reasons. Often is a busy channel, too much clients or too many interferences. Other devices like notebooks have often no problem, they have bigger antennas and a more robust wifi chip inside, than other devices like printers for example.
So when you never get a stable connection, contact your reseller, maybe the wifi board is not 100% ok. But when it works sometimes and sometimes not, I would say you have too much interferences and solving this issue is really hard and time consuming.
I would connect the printer via ethernet whenever it is possible, it is still the best solution and you don't have to struggle with network outages.
RudydG 62
Mine is in this state from the beginning. No reliable wifi connection. Don't know where the problem is. I guess my network. But there are no diagnostics utilities. So very hard to resolve.
