Video is finally working. Try swapping the ethernet cable with a working printer.
Please export the printer logs via the touch screen settings menu and upload them here or send them to me via DM. Without those we can't really see what is going on.
Chris
1
- 2 weeks later...
My work's UMS3 also had this problem when we purchased it. I tried everything I could to get it to work (different networks, ethernet, wifi, factory reset, cura connect reset, you name it) but ultimately the only thing that worked for me was to do a firmware recovery procedure with the help of my reseller. I first flashed to 5.3.10 then to 5.7.2 then I updated the firmware to 5.7.3 and I was able to get the digital factory code after rebooting the printer. If the above suggestions fail, I would ask your reseller to help you with that procedure (I did it myself all you need is a screwdriver and 45mins-1h).
Smithy 791
The video link is working for me.
One question, is the printer able to access the internet?
What happens when you try to check for new firmware updates?
