Goodmorning,
I have just updated to Cura 4.8.
However now I have problems with loading the stl-files in Cura. The building templates won't show up.
And I am not able to slice the project.
I am working with an ulitimaker original.
I am a bit of a newbee - so what kind of adjustment should I make.
Thnx
Edited by Bart35add up info.
Smithy 1,141
When you don't see the layer preview, check if you have enabled the "Force layer view compatibility mode" in the Cura preferences.
I just have double checked it on my system for Big Sur and it is as before, layer preview is working and also the zoom function is not different than before.
So I don't think it is a general problem with Big Sur and 4.8.
