GregValiant 1,320
Mari says "Keep filenames as short as possible, don't use spaces to make filename easy readable!". This is excellent advice.
The Creality machines don't deal well with filenames over 16 characters. Short names are good. I find I have to re-format the SD card every couple of weeks as well.
Mari 36
With this little information we can't really help! We don't know your machine settings nor your Cura settings!
Attach the project-file so we can see your machine settings and cura settings! -->File - Save Project
I see you only test 2 files, so it seems that one of the 2 files is corrupted or not sliced the way it should. Re-slice that file, put in on Micro-SD card and try again!
Edited by MariLink to post
