On 12/7/2020 at 11:58 AM, CarloK said:What is your Cura version?
4.8.0
I moved your question to the Cura section of this forum where it will get more attention.
I know of some problems in older Cura versions, but the problem you mention here is new to me.
If you would do a "File | Save Project" and save as a .3mf file, and then post it here, it would be helpful.
Would guess that at those points the wall is a bit thicker so that the inner wall line isn't enough to close the gaps.
Â
Try to set the setting "Fill gaps between walls" to "nowhere" (in the shell tab).
Â
Might be the fastest way to get what you want.
CarloK 104
