When you don't need the second print core, disable it in Cura, that brings more useable space.
Additionally disabling the prime blob, should also make the grey area a little bit smaller.
Let me see if I find some more settings....
1
Carla_Birch 90
Your images don't load so i'm not sure what you was trying to show in them. But why the max build volume is 215 x 215 x 200mm, a few settings will affect the max size of a part you can print.
Build Plate adhesion settings like skirt, raft, brim will all lower the max build size because they have to be printed around the outside of your model, so why your model is 205.9mm in size one way by the time you account for say a brim you could be over the max build volume.
You can set build plate adesion type to "none" what will give you more printable space, I also think some other settings can affect the overall build size but i can not recall just what ones they are, maybe @gr5 or @Smithy know just what settings can adjust the build volume more than just the build plate adhesion settings.
Also in Cura you will spot grey bars around the build plate, this is the bars that keep a safty margin for being able to print stuff like brims around a model, so when you edit the build plate adhesion settings you will see them grey bars get smaller.
