When i use bondtech firmware for some reason, the printing is fine, but it underextrudes with tinker's firmware. Any Idea why?
Have you changed the E-steps in Tinker FW?
And have you done a factory reset after installing the Tinker FW?
It is really important to do a factory reset when you change between stock and Tinker FW.
hm... let me try
It seems to work but it still is slightly underextruding. i measured off 100mm on filament and took off the nozzle to remove resistance and I extruded 100mm using pronterface but it didn't extrude the full 100mm. Its like 3-4mm short. Any ideas?
This is what the underextrusion looks like. Notice the gaps between the lines. Its kind of hard to see.
Edited by kwill5800
Smithy 761
With the Tinker FW you can set the steps directly via the menu. I don't know out of my head where it is but look through the menu.
you can also check it with the gcode M503 if I am not wrong to see the stored values.
