Here is the file an the image has an arrow pointing to where it should be a solid doughnut shape not hallow air. thanks
I'll think you'll need to make the whole model "joined all together" before you export from "Fusion 360" to Cura.
Thanks
Torgeir
Aww that's makes sense thanks for the advice.
Mari 27
... don't understand what you mean, maybe you can put arrows on the image to point out what to look for!
If you don't mind you could share the Cura Project-file with us, so we can see what your settings are!
Edited by MariLink to post
