Thanks Mari, for taking the time to respond.
Extruder temp 245, bed temp 90, I calibrated the extruder 2 days ago. I check bed level before every print, and print speed is 40 mm/sec.
I have the printer set for ABS, because on PLA the filament doesn't stick to the bed.
I think that covers you questions. 🙂
Mari 37
Is the bed correct leveled?
What temperature are you printing?
What speed are you printing?
Checked belt-tension?
Calibrated Extruder?
ABS is a litte more difficult to print with then PLA!
