Posted · Printing clear on the um2
Does anyone have experience printing clear on the um2 or any 3d printer? If so, what settings and filament do you use. Any tips? Ive been getting decent results with colorfabb ht but i wanted to see is anyone else has been able to do better.
    I did tests with PET. In short: print as slow as you can, in as thin layers as you can, and as cold as you can. Due to printing slow in thin layers, the material will sit in the nozzle for a long time and start to burn/decompose, so you might need to print even below the recommended temp range.
    See my tests here:
    - upper row printed at 50mm/s, bottom row at 10mm/s
    - layer thickness from left to right (mm): 0.40, 0.30, 0.20, 0.10, 0.06
    - dimensions of the test blocks: 10mm x 20mm x 10mm
    - watermark text is sitting halfway in the model
    A couple of years ago I made a whole thread on this, but I don't remember under which title... Maybe you can find it?
    Notice how the slowest printed blocks start to color brown due to sitting in the nozzle for a long time.
    Close-up of 0.06mm layer block:
    Close-up of 0.4mm layer block:
    Block as printed, and after polishing to remove most of the layer lines on the outside:
    Idem. Obviously, polishing the layer lines away, greatly helps improving clarity.
    Another watermark, thus hollow text sitting below the surface. Text is 3.5mm, leg-width is 0.5mm.
