GregValiant 1,316
"talc?"
Probably titanium oxide. Very white. It's used as the pigment in white paint.
"talc?"
The black prints do the exact same thing. I was thinking about widening the outer legs to get more print surface. Great idea on slowing down the print on the legs.
gr5 2,192
This is going to sound strange but I've found that white filaments do worse on overhangs and stringing than other colors. I suspect they put in some kind of powder (talc?) such that less of the material is plastic by volume than other colors which use dyes. I could be wrong about the mechanism but it doesn't seem to matter what material it is or who the manufacturer is. White just doesn't print quite as well.
Having said that, this level of crappiness in an overhang isn't all that unusual. Maybe that's at the level change? Is that the only corner that is bad? There is something called the "z seam" - maybe it's at that corner you show in the photo. Dropping the speed to 35mm/sec will certainly help the quality but might not be worth the extra print time.
It took me 100 prints to get good at ABS - I had issues that I didn't even notice in the first dozen prints. For example the parts were very weak due to bad layer adhesion but it was not obvious until I broke one and it broke along layer lines (unlike my PLA prints which break in more random directions). In general, until you get really really good at it, don't be surprised if ABS prints are much weaker.
