GregValiant 157
Where is the middle finger? Are you being nice to keep from offending our tender sensibilities? Or is it up there floating in the air someplace and causing the part origin (which is the center-of-geometry) to show up WAY off. I think that's why it won't slice, it's still way too tall. At 5% it will slice, but it shows as being almost 200mm tall.
(PS I made one of these in high school and used it as the shifter handle in my car. When I took my mother for a ride she would always bring a glove to put over it.)
DivingDuck 59
Seems, you don't model up the smallest part for printing 🙂 :
Your dimensions are 1,24m x 96,06cm x 3,85m = 1240mm x 960,6mm x 3850 mm.
Guess, your model is based on imperial units. Cura's world is in metric units and not imperial units.
There are 3 ways to solve your problem:
a) You can switch your base unit in Fusion to get an STL export in mm (best solution).
b) You can add the plugin "Barbarian Units" from Marketplace for doing the conversion.
c) You can scale it. (what Cura have already done to fit to your plate).
In addition, the origin of your model seems to be wrong too. It is outside the model.
