The preview has only colored lines and not "filament" layers.
pedroh12314
Posted (edited) · The preview has only colored lines and not "filament" layers.
When I use the slicer on an object, its preview looks awful. You can see the object, but the lines are very thin and deep color.
This only occurs when selecting "force compatibility mode".
(active) Force layer view compatibility mode
Note: if I do not select "force compatibility mode" all line types are yellow. I would definitely like to differentiate supports from the object.
Edited by pedroh12314
    Posted · The preview has only colored lines and not "filament" layers.
    You have a few features to enable/disable here to improve the view.  First of all you should zoom in (scroll wheel) and pan (hold down shift key, right click drag).
    across the top of the screen look for "color scheme".  First try "filament".  I think that's what you have it set on in the lower photo.  You can change the filament color by loading different colors in the PREPARE screen and reslicing.
    Then in "color scheme" try "line type".  I know you don't like that but it's very useful.  Yes the outer layer is red and very dark.  You can scroll through all the layers - the vertical scroll shows you each layer so you can check out if the infill is correct and look for issues with overhangs (I don't think you need any support with this model - except possibly the chin?  The shoulders look like they will be fine without support).
    • Like 3
    "Compatibility mode" is limited to what it can do. If compatibility mode could do everything, it would be the only mode.
    I understand about visualization. The problem is that I am not able to define in color scheme: type the colors that I like. Everything just turns yellow. Supports, filling ...
    Sure. I just showed you what I did to try to solve the same colors in the preview.
    Yellow is the "material color" for Generic PLA. If everything is yellow, the Color scheme is set to "Material Color". Change it to "Line Type";
    No need to be sorry. The option is fairly well hidden away, and I don't know why "Line Type" is no longer the default option like it used to be many versions ago.
    Hey - I suggested "line type" as well and gave directions.  But I guess my posts are too long to read?
        • 27 replies
