This is very common with the UM Original which is almost the same design. There are 6 pulleys on the Y axis and the 2 that are most likely the problem are the two on the "short belt" which is the belt that goes to the stepper motor.
Tighten all 6 as tight as possible. Consider marking each pulley and shaft with a tiny dot with a permanent marker so you can see which one is slipping.
Unfortunately one of the 6 pulleys is hard to get to - the one on the motor. You might have to remove the motor to get to it which probably means removing the cover also.
There are other possibilities besides slipping pulleys (with your "lean" description the other possibilities go up from 1% to 30% likely). So consider putting one drop of light mineral oil (baby oil, 3-in-1, sewing machine, or even engine oil but not grease or wd40) on each of the X,Y rods and also with power off push the print head around with your fingers seeing if there is much higher resistance on Y axis. It's possible the Y long belts are too tight causing binding and excessive friction.
Also after tightening the pulleys, if prints are still leaning, look carefully at the Y short belt as it moves back and forth - compare it to the X belt. See if you notice something different for example a twisting and report back here.
IRobertI 513
It could be that there's a pulley or two that is slipping. I would go through all of them and tighten the set screws very firmly. It could be just the pulley on the y-stepper that is causing issues but it doesn't hurt to make sure they are all tight (and it doesn't take much time at all) to make sure everything is solid.
The pulleys are the round cylinders with grooves in them that move the black belts back and forth. On the side of them there's a tiny little screw that lock them in place on the rods. Turn off the power to the printer so it's easier to rotate the screws into a position where you can tighten them.
