Hi, Yes it show empty when removed. I belive your right, its probably programmed as AA. Its brand new from printer box..
I guess it also related to the other problem as you mention.. Is it possible to overcome this or do I have to get a new printhead?
robinmdh 108
It should definitely change!, it could be that you BB printcore was programmed as an AA printcore...
unlikely as that seems, it would explain your other problem....
does the slot show as empty when the hotend is removed? (can be done without using the load/unload/change as long as no filament is keeping it in there)
