GregValiant 1,488
Don't let Geert scare you off. It's not as simple as he makes out.
#1. It's a machine. To work correctly the frame parts need to be either parallel or at 90° to each other. If the X beam (that the print head moves left and right on) isn't at 90° to the uprights, parts will be angled and leveling will be almost impossible.
The Y build table is on a beam and that beam has to be parallel to the side beams that the rubber feet are on. If the Y table is running up and down hill you can level it (because it moves past the nozzle at the same distance), but again, the parts will be tilted.
So get a carpenter tri-square and start measuring stuff for square and parallel. You can loosen screws and make the little adjustments necessary so the machine has it's best shot at getting things right.
Grab the print head and see if it wiggles or rotates. Do the same with the Y table. They should move smoothly in their tracks with no wobble, twisting, or other motion. Just back and forth on their beams. The belts should twang like bass guitar strings.
If you are leveling with a piece of paper use a store receipt or parchment paper. Something thin gives a better feel and your consistency will go up.
The build plate doesn't have any switches or locators on it to tell the printer where it is. It's up to you to get it level and at the right distance from the nozzle so when the printer spits plastic it gets squished to the plate.
A fella named Chep makes youtube videos that he calls Filament Fridays. He's pretty good. Take time to go through a couple of them. He's kind of Creality specific but all these machines have a lot in common.
1
geert_2 560
I don't know your printer, but it looks like it still needs calibrating steps, and maybe correcting slack and tolerances. You may need to find manuals and tutorials on that for your printer, or ask the manufacturer.
After that, for finding the best settings for general printing: just stay with the printer and watch it closely, while printing small test models. Do lots of test models, one by one. Change speed on the fly, and see how that affects the print quality. Change temperature on the fly, and see what happens. Change cooling on the fly, change flow-rate, etc... Print the same thing in different layer-heights and try what settings each require: thicker layers (=more material) generally require higher temperatures and/or lower speeds to melt enough material. Change parameters in small steps up and down, so you find the window where quality is optimal. This will also be different for each material.
steve010495 0
thank you i will be looking into it more, but come apon closer looking i have found thet altho my floor is abou 2 degrees out from being straight the work bench im using is at an angle and could be causing the printer frame to also tilt forward i bit. i have tighened the belt on x&y axis and used a digital measurement gauge to get the z axis strait so ,im guessing this tilt problem could be the main issue for right now? software and settings are so confusing when im not exactly sure of the terminology of the printer yet, i just learned what the zyx axis are lol
on the cura program itself i will be looking at tweeking it a little but for now i think my main consern is this tilt the leveling is almost spot on each time from the bed its 0.5mm from bed to nozzle in all corners however between the right hand side of the bed between top and bottom screws its touching the bed in the middle ( same on the left side too) but i thought as long as the bed was level to the corners the middle between the screws would be the same as the corners even on a slight tilt
