GregValiant 1,330
I often use Z-hop if a print has a largish horizontal hole or arch that may want to curl up during printing. If the curl catches on the nozzle it can push the print. My preference for those types of parts is 0.5 to 1.0 of Z-hop.
I know it's a question of semantics, but reading it carefully "Z-Hop only over printed parts" limits Z-hops within a particular part. It isn't the same as Combing mode. And as gr5 says, there are numerous other settings that have an effect on Retraction and subsequent Z-Hops. It isn't an easy setting to understand (but what in 3D printing is?).
1
redoctober45 1
Since you mentioned it, first may I ask why you don't use zhop? I am pretty new to Cura. Used S3D for a long time, though I always used zhop, I still never experienced nozzle drag until now.
Are there maybe settings in Cura I am missing to reduce/eliminate it and thus not need the zhop?
Thank you
