Hi John,
I'll think as Geert, -try using mold and epoxy resin. 🙂
Epoxy is a very good insulator, but will suffer if heat is to high (but normally a bit over 100 deg. C).
There's plenty of brands, so if you can find one with increased heat properties it may fill your needs.
You can also mix in the color you'd like.. (But check for type).
Torgeir
1
geert_2 560
I would have some doubts about carbon-filled materials. The leads of pencils are carbon-filled too, and are *highly conductive*: short-circuit a battery with a pencil lead, and you get a really nice welding arc... Black anti-static mats get their properties from the carbon too.
Make sure you measure conductivity on a small test print, and also the breakdown voltage.
So the glass-filled looks like a better idea to me.
Maybe PET should also do, at least for normal house-hold voltages? But I have no clue about its high-voltage properties.
Also, have a look at the working temperature at high loads: some equipment might run at 100°C or more, too high for most 3D-printing materials. In that case, you might consider printing a mould, and casting it in a thermoharder or two-component material. Maybe that is why they used bakelite in the first place?
JohnInOttawa 104
Those are all good considerations. I am wondering if a mold is the right solution here as well. One aspect I had not considered when I posted originally is that the air gaps present in normal FDM printing can defeat any intrinsic insulating qualities in the filament itself and can contribute to shock hazard around higher voltages.
This VARIAC can increase output voltage above the source value and is rated over 500V so to your point, maybe I need to weigh what the original designers considered and go with their solution too.
J
