https://fbrc8.com/products/heated-bed-panel-and-cableum3-um3x
Okay I can see in the picture at the above link that it's a press fit connection. I'd fill those connectors with a bit of solder as it seems to me that's the most likely point of failure. You could check the other end of the cable under the printer but with the print bed going up and down often and with experience from my UM2 heated bed failure I suspect those press fit connectors (or whatever they are called). Again - the smaller 2 wires - where they connect to the heated bed in the photo above.
gr5 2,234
er14 is definitely related to build plate. Not cores. Not print head.
If you go to the web page it's pretty clear it is seeing max temp. Which is something like 500C. Which means your house has been placed in a furnace. Or there is a problem reading the temp sensor. If there is an open (for example broken wire) you will get this error.
Usually the problem happens right at the connector. I'd take apart the print bed and unscrew the cable and carefully remove the build plate without twisting the wires too much. The larger 2 wires go to the heater. Your problem is the sensor - the smaller 2 wires. Maybe take a photo of how that connector works. There's many ways for the failure to occur. Do you have a soldering iron or a friend who does? Maybe reflow the solder - I'm not sure what the UM3 buildplate looks like as I've only taken apart my UM2 buildplate and the UM3 is likely different. Maybe remove the two sensor wires, make sure they are clean, and put them back in there nice and tight.
