set "travel avoid distance" to zero.
disable brim and skirt both!
details here:
https://support.ultimaker.com/hc/en-us/articles/360013799339-How-to-print-the-maximum-build-volume-in-Ultimaker-Cura
details here:
So look at all the "horizontal expansion" parameters (search for them in the settings search box). If you have any kind of support turned on then that could be the problem. Do you have support enabled? Your part doesn't seem to need it so turn it off.
There is "initial horizontal expansion" and regular "horizontal expansion".
Just now, gr5 said:set "travel avoid distance" to zero.
disable brim and skirt both!details here:
Already been through that article and set those. No change.
I only have Travel Avoid set, which is the darker 1mm band you see all around. The 2mm band you see at the top refuses to go away, despite going through every single print setting one by one.
Just now, gr5 said:So look at all the "horizontal expansion" parameters (search for them in the settings search box). If you have any kind of support turned on then that could be the problem. Do you have support enabled? Your part doesn't seem to need it so turn it off.
All those are off already. I'm going crazy here! Been looking at this for a total of 6 hours
Could it be related to some clips or things on your print bed? There's a ".def.json" file that describes your printer somewhere. The nicer json files have more information in them including intricate details or your print bed. The file should be in a folder called "definitions". somewhere. Files look something like "anycubic_i3_mega.def.json" (example that will be in that folder).
Even weirder... restarted Cura, no margins. Import the STL, margins appear... could it be something in the STL file from Fusion 360? Is it a model setting in Cura?
11 minutes ago, gr5 said:Could it be related to some clips or things on your print bed? There's a ".def.json" file that describes your printer somewhere. The nicer json files have more information in them including intricate details or your print bed. The file should be in a folder called "definitions". somewhere. Files look something like "anycubic_i3_mega.def.json" (example that will be in that folder).
I think you might be onto something...
In the def.json for my printer, it has this - think it's related?
"machine_disallowed_areas": {"default_value": [[[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]],[[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]
You were right. Ultimaker added these as a way to prevent newbies from damaging their nozzles by bashing into the clips. However, I long ago removed the clips when I went to a PEI bed sheet.
My thinking is I can remove the two rows entirely (top and bottom of the bed sheet) which should open the whole bed back up for printing...
It worked! Thank you so much @gr5!!
Realize that when you next upgrade Cura you will have to edit that file again.
"...Ultimaker added these as a way to prevent newbies from damaging their nozzles..."
Not Ultimaker. Near the top of your *.json definition file will be a line like this one from my Creality Base definition file: "author": "trouch.com".
PhoToplex 1
What's causing these two grey bands along the far left and right of the bed area? It seems these are the cause, but they shouldn't be there. The top and bottom do not have them, and shows the whole length area.
